  • 1.  Connect aruba RAP to Instant Acces Point Controller
    Posted May 10, 2018 04:18 PM
    Hello Community,
    So, my question is the Aruba RAP 303H can connect to Instant Acces Point 305 Controller?
    So do I need a physical connection to connect the Remote AP to network?
    hope your comments,
    regards
  • 2.  RE: Connect aruba RAP to Instant Acces Point Controller
    Posted May 10, 2018 08:39 PM
    For either RAP operation or IAP-VPN, you need to terminate onto a mobility controller, not an Aruba Instant VC.
    thanks,
  • 3.  RE: Connect aruba RAP to Instant Acces Point Controller
    Posted May 11, 2018 03:11 PM
    so the connection to RAP is Wirless or Wiredd?
  • 4.  RE: Connect aruba RAP to Instant Acces Point Controller
    Posted May 16, 2018 12:08 AM
    Hi Javier,
    Both IAP 305 & 303H use the same image version. So, they can form a
    cluster.
    However, 303H needs minimum version 6.5.2.0.
    So, please ensure IAP is running atleast 6.5.2.0 Or above version. Once that is confirmed, you can add IAP 303H in to the same cluster & it should work fine.
