  • 1.  Connect IAP 2015 against Radius
    Posted Jul 19, 2016 05:15 AM
    Hi all
    I have two IAP 205 that I am using in a POC, for connect to the enterprise network.
    Client says that has a Radius server for Vlan Control.
    What is needed on the IAP for connect against the Radius server? Add the radius IP on the config?
    I am not familiar with Radius, only know that they are like AAA servers .
    Regards
  • 2.  RE: Connect IAP 2015 against Radius
    Posted Jul 19, 2016 08:59 AM
    Who maintains the radius server?  It is very straightforward to connect an IAP to the radius server.  To make the user switch VLANs, the Radius server would have to send back the Aruba-Vlan-Attribute in the radius response to set the VLAN.  That VLAN would have to be trunked to the wired port of the IAP.
  • 3.  RE: Connect IAP 2015 against Radius
    Posted Jul 20, 2016 10:42 AM
    Hi
    The radius is from the client.
    But do I have to configure some parameters under the virtual controller?
    Regards
