Wired Intelligent Edge
connecting 2 ISP's Gateway on aruba 2930F
  • 1.  connecting 2 ISP's Gateway on aruba 2930F
    Posted Aug 07, 2022 06:48 PM
    Hello
    I have 2 ISP's gateway modem connected on switch aruba 2930F
    I would like to make  active/passive configuration between 2 modems without change any thing at the end-user side or make any configuration change at the ISP modem
    Any help
  • 2.  RE: connecting 2 ISP's Gateway on aruba 2930F
    Posted Aug 08, 2022 01:17 AM
    Hi
    Could you please share your current configuration and a drawing/description of your current logical network design? Can we assume your 2930F is the router in your network for the end-user networks/VLANs?
    Kind regards,
    Thomas
  • 3.  RE: connecting 2 ISP's Gateway on aruba 2930F
    Posted Aug 08, 2022 02:59 AM
    What are the CPE/ ISP modems configuration like ? Do they run a common HSRP/VRRP or similar ?
    How exactly do you want to achieve the A/P redundancy ?
