Or use AP-ANT-345.
Original Message:
Sent: Sep 26, 2024 03:36 PM
Subject: Connecting AP-ANT-345 to AP-634 Access Point
ANT-325 is a two port antenna. You'd need two of the ANT-325 for an AP-634.
Carson Hulcher, ACEX#110
Original Message:
Sent: Sep 26, 2024 02:09 PM
Let's assume Port 1 to 4 is WLAN1 to WLAN4 correct?
If by chance we had the AP-ANT-325, Iris is adding two of them which doubles the price which I believe is an error since it comes with 4 connectors ??
Aruba Partner Ambassador ACMP, ACDP, ACCP, ACEP
Original Message:
Sent: Sep 24, 2024 01:50 PM
A0 and A1 are dual-band. B0 and B1 are 6 GHz.
Connect A0 to port 1 on the antenna.
Connect A1 to port 2 on the antenna.
Connect B0 to port 3 on the antenna.
Connect B1 to port 4 on the antenna.
Doing this will result in each radio having a cross-polarized antenna setup.
Original Message:
Sent: Sep 24, 2024 12:59 PM
I'm not sure I'm following what you are saying. On the AP I have A0 (2.4GHz connection), A1 (5GHz connection), and B0 B1 (6GHz connections). Which cables, WLAN1, WLAN2, WLAN3, WLAN4, go to each connection?
Original Message:
Sent: Sep 24, 2024 12:11 PM
All ports on that antenna are tri-band, so from that perspective it does not matter.
However, you would want two 90 degrees cross polarized elements to be connected to each radio.
To do so, connect ports 1 and 2 to one radio, and ports 3 and 4 to the other radio.
1+4 and 2+3 works as well, but combining 1 and 3 or 2 and 4 (co-polarized elements) is not recommended.
/Onno Harms, Aruba Wireless Product Management
Original Message:
Sent: Sep 24, 2024 11:54 AM
I have six AP-634 access points that I will be connecting AP-ANT-345 antennas to. I have not been able to find much information out there on which antenna cables go to which antenna connectors on the AP-634. I know that A0 and A1 are for 2.4GHz and 5GHz and B0 and B1 are for 6GHz, but there's no documentation with the AP-ANT-345 or AP-634 explaining which cables to connect to each connector. The cables on the AP-ANT-345 are labeled WLAN1, WLAN2, WLAN3, and WLAN4. Am I to assume that A0-WLAN1, A1-WLAN2, B0-WLAN3, and B1-WLAN4?
