Comware
Connecting HP 5900 to HP 5700
  • 1.  Connecting HP 5900 to HP 5700
    Posted Jan 27, 2025 07:26 AM
    Edited by capricorn80 Jan 27, 2025 08:34 AM
    Hello!
    I have a network already in place running two HP 5700 series switch in IRF mode. I have Aruba switches in access/distribution layer. Basically its only two layers. I have HP 5700 in core layer and Aruba switches are next to it with users and servers are connected to it. I have around 12 VLANS for different purposes and VLAN interfaces are connected to FW with VLAN Trunk between Firewall and HP 5700 switches. The current setup works fine.
    Now I have to configure two HP 5900 series switch in our Test environment and will replace a old router. The HP 5700  are connected via layer transport link with point to point IP address.
    I will connect the HP 5900 series via layer 3 point to point IP as well.
    I am planning to configure a MGMT IP address from 10.1.1.0/24 subnet on MGMT port on the HP 5900 series switch because 10.1.1.0/24 will not be used in the TEST LAB for routing/switch purpose.
    I am planning to configure IRF on HP 5900. I have never configured it before but I can do it without conflict with HP 5700 as they will be connected via Layer 3 link?
    I am planning to configure HP 5900 STP as .
    stp instance 1 priority 32768
    My HP 5700 has
    stp instance 0 priority 8092.
    Instance  VLANs Mapped
       0         1 to 4094
    Should I create another instance for MSTP or I can use the same instance as 0 and higher the priority for 5900 series switches?
    Does this look ok from MSTP prospective and for IRF I can create different Domain ID like 10 so that it will not interfere with my HP 5700 or as they are two different region then it doesn't matter?
    I am uploading the network topology pic as well for review.
    Thanks for your input on this.
