Comware
connecting secondry IRF power cable and bringing it on again
  • 1.  connecting secondry IRF power cable and bringing it on again
    Posted May 12, 2025 05:44 AM
    Edited by capricorn80 May 12, 2025 05:45 AM
    Hello!
    I have two node IRF configure and it was working fine. Due to some power outage we had to turned both of them.
    Member 1 has higher priority then Member 2.
    Both were up and working until we had issue with our power  outage and I only turn on the Member 1 and didn't get a chance to turn on Member 2 at that time.
    I will turn on the Member 2 but I want to check if turning it on will create any down time or some glitch or some sync that can effect the network?
    I haven't done this before and as our network is live so I need to be sure that nothing can happen when I power on the member 2.
    Thanks for your input on this.
