Wired Intelligent Edge
Connecting two ProCurves Together-Best Practices
  • 1.  Connecting two ProCurves Together-Best Practices
    Posted Apr 07, 2015 03:13 PM
    I am seeking to connect two Procurve 2530 48 port switches together. I have the main connection going into one switch from a Watchguard XTM 3 series firewall with a builtin switch and was trying to figure out the best way to connect all three of these devices together. Should i just daisy chain them together or configure them as a triangle then configure STP? If STP is the case can someone provide some insight regarding setting up STP on these devices if and what i should consider?
  • 2.  RE: Connecting two ProCurves Together-Best Practices
    Posted Apr 07, 2015 06:49 PM
    Your diagram looks sensible.
    1st step is to check what versions of spanning tree the devices can use to interoperate and configure them accordingly.
    Make sure you use a version that does "rapid".
    2nd step is to configure your firewall/switch with a lower STP priority.
    3rd step is to configure the "edge"(ie, not link ports) Procurve switchports as admin-edge-port
    4th step is to configure the "edge" ports with either:
         - bpdu-protection (disables ports that receive a BPDU), or
         - bpdu-filtering (ignores BPDUs), or
         - root-guard (allows and uses BPDUs, but will not allow the STP root to move to these ports)
    5th step is configure loop-protect on all "edge" ports.
