I'm new to Vlans so please excuse my ignorance. I have one vlan on one switch 192.168.167.1/24 with 6 untagged ports, each connects to a single device. I have a second switch with a Vlan 192.168.167.254/24 with 10 untagged ports. Both switches are HP2530-48p. Each switch also have a default Vlan encompassing the other ports. The default vlan and the second Vlan on the same switch that I added do not need to talk to each other, just the two 2nd vlans on each switch need to talk to each other. I tried connecting vlans together with a patch cable to/from one port & it caused issues with some devices unable to talk to other devices even if on the same switch vlan. How best can I connect both Vlans together to make a 16 port vlan across the two switches? I think part of my issue is is using 192.168.167.1 as a gateway on one and 192.168.168.254 as a gateway on the other - I'm thinking now they should be the same gateway on both switches. Currently the Vlan IP is the same as the gateway on each device, so as .1 one one switch and as .254 on the other. I think maybe I can use .254 as the VLAN IP on the second switch but should use the .1 as the gateway if I want the two VLANs to talk to each other - right?
Do I need to use a trunking port on each VLAN to connect the two or a tagged port?
A secondary question which is not as important as above is connecting VLAN to the Internet. The other ports on each switch using the default VLAN connect to the Internet using a different gateway IP, currently there are 5 HP2530 switches in this network, each switch is connected to the next switch with a simple jumper. Ie, switch 1 has port 48 jumpered to port 47 of switch 2. Switch 2 port 48 is jumpered to port 47 of switch 3 and so on. The last switch has port 48 connected to an Aruba 24 port switch with that switch connected to a primary and backup Watchguard appliance, that is connected to a fibre drop for Internet.
To connect this 16 port vlan from above to the Internet, would I just take one port from the vlan and connect it to my 24 port Aruba switch where if correctly configured, would then connect thru the watchgaurds to the fibre drop?
I do not want the 16 port vlan to communicate with the other network, only to connect to the same Internet drop.
Finally, with the five switches connected together by looping one to the next, and that to the next one, while it works with computers in all switches able to talk to each other and shared printers, etc., is this the best way to do this or should the ports be trunked ports or some other configuration?
I greatly appreciate any advice & help on connecting these 2 VLANs
Thank you. π
Ken Crook
Ch. Engineer Broadcast/IT
kcrook@rawlco.com------------------------------
