Connecting with 5GHz then continueing with 2.4 GHz
  • 1.  Connecting with 5GHz then continueing with 2.4 GHz
    Posted Apr 29, 2014 10:16 AM
    Hello Friends,
    Would you help me? How should I config the controller if I want a client to be connected to the AP with 5 GHz bandwidth when the 5 GHz antenna will be correptud, The client should continue to be connected with 2.4
    Is there any solution that I can test this ???
  • 2.  RE: Connecting with 5GHz then continueing with 2.4 GHz
    Posted Apr 29, 2014 10:34 AM
    What version of AOS are you using ?
    pre-6.3 you need to enable BandSteering will steers devices to connect to 5 GHz but if you are using 6.3 then ClientMatch also has the band steering functionality
