To make MC-LAG work, you need to meet certain requirements. One of it being VSX configured correctly with a common system-mac per VSX cluster. Furthermore, VSX shall be in-sync and MC-LAG interfaces need to have the correct physical interfaces as members.
None of these things can be confirmed by just the diagram. So, kindly, post the output of the following commands (from all 4 switches):
- show vsx status
- show lacp interfaces
- show run vsx
- show run int lag XX (<-- where XX represents the LAG number of the links between the clusters)
- show run int 1/x/y (where 1/x/y represents the physical interfaces between the two clusters)
- show lldp neighbor
You may sanitize/strip down the output to relevant parts.
Moreover, maybe that discussion can help, too: https://community.arubanetworks.com/discussion/arubaos-cx-switches-vsx-and-mc-lag
Thomas
Original Message:
Sent: May 13, 2025 04:53 PM
Subject: Connectivity between 2 vsx pairs using multichasis lag
In this scenario.. i see the interfaces connected between the switch pairs are showing up as LACP block. They are configured as multichasis lag ports.
