Become a Member
Quick Q - possible to increase the console baud rate? 9600 is hurting with the amount of logs and stuff I'm dealing with. Combed the internet (and the user guide) for the answer but couldn't find the command. Thanks!
I don't believe you can change that. Most of the time I will go in via SSH to get around that. You could also download the logs and then look at them.
