Skip main navigation (Press Enter).
Log in
Toggle navigation
Log in
Home
Discussion Forum
Support
Documentation Portal
Support Knowledge Base
HPE Networking Support Portal
HPE Aruba Networking Central Status
Live + Virtual Events
Webinar Archive
Upcoming Events
News
Technical Blog
ACEX Hall of Fame
MVP Program
Become a Member
Comware
Community Home
Discussion
56.8K
Members
750
Back to discussions
Expand all
Collapse all
sort by most recent
sort by thread
Console Cable for 2524
Jorge Jerez
Mar 24, 2007 03:30 PM
Hi. I losed the cable to connect my procurve 2524 switch to the serial port of my computer. Does a standad ...
razzer
Mar 24, 2007 06:39 PM
i believe it is a standard ethernet cable.like rj45.though i am not certain.
Joel Belizario
Mar 25, 2007 04:37 PM
This is the description from HP Partsurfer: 5184-1894, RS-232C serial cable - 9 pin (F) to 9 pin (F) ...
OLARU Dan
Mar 25, 2007 10:06 PM
You can use any console cable that comes with any HP ProCurve switch, if some netadmin you know has ...
Christer Olsson
Mar 25, 2007 11:34 PM
The cable is a standard DB9(F) - DB9(F) nullmodem so you can buy a cheap one from your local datastore. ...
1.
0
Kudos
Jorge Jerez
Posted Mar 24, 2007 03:30 PM
Reply Privately
Options Dropdown
Hi. I losed the cable to connect my procurve 2524 switch to the serial port of my computer. Does a standad serial cable works to connect to hyperterminal? Do i need a specific cable? which? lot of thanks.
2.
RE: Console Cable for 2524
0
Kudos
razzer
Posted Mar 24, 2007 06:39 PM
Reply Privately
Options Dropdown
3.
0
Kudos
Joel Belizario
Posted Mar 25, 2007 04:37 PM
Reply Privately
Options Dropdown
5184-1894, RS-232C serial cable - 9 pin (F) to 9 pin (F) - 2.5m (8.2ft) long - Connects a terminal or computer to the console port
4.
0
Kudos
OLARU Dan
Posted Mar 25, 2007 10:06 PM
Reply Privately
Options Dropdown
You can use any console cable that comes with any HP ProCurve switch, if some netadmin you know has and is willing to help you.
5.
0
Kudos
Christer Olsson
Posted Mar 25, 2007 11:34 PM
Reply Privately
Options Dropdown
Null-modem cables is a cable connecting following pins:
1---7
7---1
2---3
3---2
4-6,8
6,8-4
5---5
G---G
New Best Answer
This thread already has a best answer. Would you like to mark this message as the new best answer?
Related Content
brocade 2800 serial cable
Supreme_Dalek
Added Aug 16, 2011
Discussion Thread
1
DB9 to DB9 serial connection for console on hp surestore (brocade) entry switch?
John Jimenez
Added Dec 22, 2003
Discussion Thread
1
5400 series console connections (USB - DB9)
zyto
Added Apr 17, 2010
Discussion Thread
4
pin out of X25 switch console
adnane
Added Jul 25, 2003
Discussion Thread
1
Remote serial console access?
Alastair Harrison
Added Feb 26, 2009
Discussion Thread
3
Copyright 2024. All rights reserved.
Powered by Higher Logic
