It's not possible to disable the console port. It is recommended to harden the configuration and apply authentication on the console port. Please also check the CX hardening guide.
Willem Bargeman
Systems Engineer Aruba
ACEX #125
Original Message:
Sent: Mar 05, 2025 10:36 AM
Subject: Console port
Hi, does anyone know if the console port can be disabled on AOS or CX switches?
I have found how to disable the USB console port on a 2930f, but not the port Rj.
