  • 1.  Console User & Password not working on AP635
    Posted 27 days ago
    I've been trying to get the console access to the Aruba AP 635 and it prompts me to enter user: and password:
    I entered the below:
    user: admin  (both with upper & lower case)
    Password: serial number of the AP   (both with upper & lower case)
    Does anybody knows what are the right credentials?
    WIMR
  • 2.  RE: Console User & Password not working on AP635
    Posted 27 days ago
    That should work, unless the AP is already configured, and after first login a new password has to be set. A factory reset may help in that case.
    Another option is that this AP is managed through Central or Airwave, in which case the password is set through the configuration. If an AP is managed, after a factory reset it will automatically connect back and push the configuration that is in Central or in Airwave.
    If you got the AP delivered directly from the factory, you should be able to login with admin and the serial number (upper-case). If you got it through a previous owner, very likely it's still being managed.
