  • 1.  Controller ArubaOS 8.7.1.8 275 Outdoor APs
    Posted Mar 17, 2022 02:04 PM
    Hi Everyone
    I have deployed a VMware Controller ver 8.7.1.8, 8 indoor 207 access points and 2 275 outdoor access points. l added all the 10 APs and SSID into one AirGroup.
    The indoor APs are working fine but the outdoor 275 APs are not broadcasting any SSIDs l have trial licence for 25 APs
    Please help
    Regards
    Micaiah
    micaiah kaseke
  • 2.  RE: Controller ArubaOS 8.7.1.8 275 Outdoor APs
    Posted Mar 17, 2022 03:10 PM
    Do the APs show up in the ap database "show ap database"
    Have you checked to see if the APs are stuck in instant mode? Try to access the APs IP by CLI/WebUI. If they are on a different subnet than the indoor APs, and controller discovery if not configured correctly they might boot up in instant mode.
    Dustin Burns
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022
  • 3.  RE: Controller ArubaOS 8.7.1.8 275 Outdoor APs
    Posted Mar 17, 2022 04:28 PM
    Also, what are the flags showing up for outdoor APs, you can get it from show ap database ​
    Kumara Vinod
  • 4.  RE: Controller ArubaOS 8.7.1.8 275 Outdoor APs
    Posted Mar 18, 2022 02:29 AM
    Also check for the power issues. Outdoor APs may need more power and if they cannot get, wont publish SSIDs.
    Best regards,
    husnu demir
