Now with 8.4.0.0 it should be possible. But is there a tech note how to configure it when using mds in cluster?
I set up a lab but it wan't work. I think the RAP tries to connect to the wrong controller because of AP loadbalancing. But how can we bring the RAP to the active controller???
On both controller the AP is flagged as 2, with different switch ip. See the logs:
Received MAP_ADD from IKE for default-ha-ipsecmap172.21.4.181 (gw 172.21.4.181) mapid 0 vlanid 0 ip 172.21.4.181 mask 255.255.255.255 src_ip 172.21.4.182 peer_ip 172.21.4.181 uplink_ip 0.0.0.0 flags 0x0
Jan 17 14:25:32 cluster_mgr[4263]: <352302> <5214> <ERRS> |cluster_mgr| cmlb_ap_handle_ap_down_request, No entry in active table in LB-AP thread for AP with mac 00:4e:35:c0:50:ce
The RAP system-profile:
ap system-profile "rap"
lms-ip x.x.x.126
bkup-lms-ip x.x.x.127
ap-console-password f07f0060babda0eb9d334d06ef1ebf796c88bc7e849bf3d0
bkup-passwords 0709bf2b2078b3fe6c4366c3dcf8b517f4655c2841b47cb3
As soon as i would replace the primary lms ip to .127 it would work.
Greets Marc
