  • 1.  Controller debug limits
    Posted Jan 20, 2016 09:20 AM
    I get asked this question a lot, but do not know the official answer to it so I thought I post it out there as I cannot find any community links about it. So here goes...
    In the controller you can run debug for various things, the common debug I have used is the user-debug. Is there any limit on the amount of debug you can run on the controller when it starts impacting performance. For example, is there a limit on the amount of user debug you can run from the controller?
    Also, is there a limit on the other debugs as well ?
  • 2.  RE: Controller debug limits
    Posted Jan 20, 2016 09:40 AM
    I would run a "show cpuload" on the controller before your turn on debugging.  If at any time it stays at 80% or above, I would not turn on debugging.
    After you turn on debugging, once again check to make sure it is not at 80% or above sustained.  If it is not, you are probably okay.
  • 3.  RE: Controller debug limits
    Posted Jan 20, 2016 09:49 AM
    Thank you for the answer.
    So what I get from your answer is the amount of debugs that could be run on a controller depends on the resources of the controller ? Is this correct ?
  • 4.  RE: Controller debug limits
    Posted Jan 20, 2016 10:59 AM
    Correct.
