  • 1.  Controller Downgrade Firmware
    Posted Sep 25, 2017 04:40 AM
    After upgrade the firmware to version 8.1, can i still downgrade to 6.5 or 6.4?
  • 2.  RE: Controller Downgrade Firmware
    Posted Sep 25, 2017 04:49 AM
    i have done it, because of stability problems with version8. You should do a flash backup of your 6.x installation. than you can just install version 6 and restore the backup. There is no downgrade option in version 8
  • 3.  RE: Controller Downgrade Firmware
    Posted Sep 26, 2017 04:00 AM
    In version 8, does it still have 2 partition to keep different version of the OS?
  • 4.  RE: Controller Downgrade Firmware
    Posted Sep 26, 2017 04:04 AM
    Yes, AOS 8 does have 2 partitions..
