Hi
I got this strange problem in which controller will lose connection to switch ( 2920 -24g) .
It is a test environment , there is minimal load .
I am using HP protector 1.3.13.458 , HP SDN controller 2.5.15.1175 and our custom build app
Anyone can provide a pointer on how to troubleshoot the problem ?
[2015-07-27 01:36:59.077] ERROR http-bio-8443-exec-508 hp.keystone Failed to validate token 2250accef6414d17b97de9f6e41be635 due to com.hp.api.auth.AuthenticationException: Validation error code 404
[2015-07-27 01:36:59.092] WARN of-io-74-thread-6 hp.of.ctl Datapath REVOKED: 10:00:40:a8:f0:ce:86:40, neg=V_1_3, ip=192.168.10.101
[2015-07-27 01:36:59.092] INFO DpQPool-9-thread-6 com.mimos.nc.listeners.SwitchListener DE0005I SwitchListener event DATAPATH_REVOKED
[2015-07-27 01:36:59.092] ERROR of-io-74-thread-6 hp.of.ctl Intercepted unexpected exception: java.lang.IllegalStateException: Main connection already established for dpid 10:00:40:a8:f0:ce:86:40
com.hp.of.ctl.impl.OpenflowController.panic(OpenflowController.java:1151)
com.hp.of.ctl.impl.OpenflowController.newMainConnectionReady(OpenflowController.java:859)
com.hp.of.ctl.impl.OpenflowController.handshakeComplete(OpenflowController.java:848)
com.hp.of.ctl.impl.OpenflowMessageBuffer.handshakeComplete(OpenflowMessageBuffer.java:234)
com.hp.of.ctl.impl.OpenflowConnection.inBoundFeaturesReply(OpenflowConnection.java:256)
[2015-07-27 01:37:00.080] ERROR http-bio-8443-exec-527 hp.keystone Failed to validate token 2250accef6414d17b97de9f6e41be635 due to com.hp.api.auth.AuthenticationException: Validation error code 404
[2015-07-27 01:37:08.490] WARN of-idle-timer hp.of.ctl Closing unresponsive connection from 192.168.10.101
[2015-07-27 01:37:08.492] INFO of-idle-timer hp.of.ctl Datapath removed: 10:00:40:a8:f0:ce:86:40, neg=V_1_3, ip=192.168.10.101
[2015-07-27 01:37:08.492] INFO devown-lh-18-thread-4 com.hp.magellan.ha.MagellanSystem Device Owner event type: OWNERSHIP_LOST. Datapath ID: 10:00:40:a8:f0:ce:86:40
[2015-07-27 01:37:08.492] INFO devown-lh-18-thread-4 com.hp.magellan.ha.MagellanSystem New owner: null
[2015-07-27 01:37:08.492] INFO DpQPool-9-thread-6 com.mimos.nc.listeners.SwitchListener DE0005I SwitchListener event DATAPATH_DISCONNECTED
[2015-07-27 01:37:08.492] INFO DpQPool-9-thread-6 com.mimos.nc.listeners.SwitchListener DE0005I Remove switch 10:00:40:a8:f0:ce:86:40 Clear client lists
[2015-07-27 01:37:08.493] INFO DpQPool-9-thread-6 com.mimos.nc.impl.NetworkAccessControlSwitchManager DE0005I --[NetworkAccessControlSwitchManager removeSwitch] Removed switch 10:00:40:a8:f0:ce:86:40
[2015-07-27 01:37:08.493] INFO MsgDispatcher-5932-thread-1 com.hp.magellan.devicethrottling.ThrottlerServiceImpl DE0005I Stopping device counter for dpid 10:00:40:a8:f0:ce:86:40.
[2015-07-27 01:37:08.492] INFO devown-lh-18-thread-4 com.hp.magellan.ha.MagellanSystem Previous owner: null
[2015-07-27 01:37:08.493] INFO devown-lh-18-thread-4 com.hp.magellan.ha.MagellanSystem Is the controller master for the dpid 10:00:40:a8:f0:ce:86:40? true
[2015-07-27 01:37:08.493] INFO devown-lh-18-thread-4 com.hp.magellan.ha.MagellanSystem Stopping device actor for dpid 10:00:40:a8:f0:ce:86:40.
[2015-07-27 01:37:08.494] INFO .actor.default-dispatcher-24 com.hp.magellan.ha.actor.ControllerActor Received device message: {dpid: 10:00:40:a8:f0:ce:86:40, request: STOP}
[2015-07-27 01:37:08.494] INFO .actor.default-dispatcher-24 com.hp.magellan.ha.actor.ControllerActor Stoping device actor for dpid: 10:00:40:a8:f0:ce:86:40
[2015-07-27 01:37:08.494] INFO .actor.default-dispatcher-23 com.hp.magellan.bandwidthmonitor.actor.BandwidthControllerActor Stoping device bandwidth actor for dpid: 10:00:40:a8:f0:ce:86:40
[2015-07-27 01:37:08.494] INFO .actor.default-dispatcher-23 System.out [ERROR] [07/27/2015 01:37:08.494] [mysystem-akka.actor.default-dispatcher-23] [akka://mysystem/user/bandwidthcontrolleractor/bandwidthactor10:00:40:a8:f0:ce:86:40] Kill (akka.actor.ActorKilledException)
[2015-07-27 01:37:08.495] INFO .actor.default-dispatcher-23 System.out [ERROR] [07/27/2015 01:37:08.494] [mysystem-akka.actor.default-dispatcher-24] [akka://mysystem/user/controlleractor/deviceactor10:00:40:a8:f0:ce:86:40] Kill (akka.actor.ActorKilledException)
[2015-07-27 01:37:08.550] INFO sdn-topo-12-thread-1 hp.sdn.net.topo DE0005I Received new topology: DefaultTopology{supplierId=com.hp.sdn.topo.compute, activeAt=2015-07-27T05:37:08.550Z, deviceCount=0, clusterCount=0, linkCount=0, data=DefaultTopologyData{ts=418637434599668, computeTime=28us}} due to: DEVICE_AVAILABILITY_CHANGED:1
