Controller Scaling for Remote APs Deployment
  • 1.  Controller Scaling for Remote APs Deployment
    Posted May 05, 2017 09:58 AM
    Hi All,
    I am scaling controller for Remote APs deployment. While scaling i found one table "Mobility Controller – Remote Deployment" in Aruba Mobility Controllers VRD v9, for reference i attached that table with this thread. I have confussion in this table, let say i have number of 32 RAPs and total of 128 associated device then i will select controller 620. but if i have same 32 RAPs but the number of users are 256 then in that case i will select same 620 controller because i am not crossing the limit of maximum IPSec tunnels, but as per VRD they select 650. So why they select the 650???
