Convert a RAP-2 to Campus Ap
  • 1.  Convert a RAP-2 to Campus Ap
    Posted Aug 03, 2013 02:29 PM
    Anyone know How can I convert a RAP-2WG to Campus Ap?
  • 2.  RE: Convert a RAP-2 to Campus Ap
    Posted Aug 03, 2013 02:31 PM
    RAP-2's can only operate as a remote AP.
    Sent from my BlackBerry Z10
  • 3.  RE: Convert a RAP-2 to Campus Ap
    Posted Aug 03, 2013 02:33 PM
    Also, just because it is operating as a RAP, doesn't mean you can't use it in the campus environmnet. Just make sure your public controller endpoint IP is accessible from inside your network.
  • 4.  RE: Convert a RAP-2 to Campus Ap
    Posted Aug 03, 2013 02:49 PM
    Cappalli,
    I read on the Product Line Matrix that the RAP-2 can support the convertion to CAP.
    Is because I have that doubt.
    I send the .pdf if you can chek this part.
    Regards
    Attachment(s)
    pdf
    MAT_RAP.pdf   685 KB 1 version
  • 5.  RE: Convert a RAP-2 to Campus Ap
    Posted Aug 03, 2013 03:26 PM
    Does it show up in the AP Installation screen on your controller?
  • 6.  RE: Convert a RAP-2 to Campus Ap
    Posted Aug 03, 2013 08:06 PM
    @chbaca wrote:
    Boot it up new on the same subnet as a controller and it will function as a CAP.
  • 7.  RE: Convert a RAP-2 to Campus Ap
    Posted Aug 04, 2013 08:09 PM
    Hello Collin
    Question here.
    this is not recommended by Arubanetworks standpoint doing that? i mean putting rap2 as Campus AP or its okay?
    Cheers
    Carlos
  • 8.  RE: Convert a RAP-2 to Campus Ap
    Posted Aug 04, 2013 08:16 PM
    It is not recommended, no.
  • 9.  RE: Convert a RAP-2 to Campus Ap
    Posted Aug 04, 2013 08:17 PM
    Thank you for the clarification!
  • 10.  RE: Convert a RAP-2 to Campus Ap
    Posted Aug 04, 2013 08:18 PM
    They weren't designed for the load of a campus environment. Especially the
    RAP-2 which is designed for 3-4 devices.
  • 11.  RE: Convert a RAP-2 to Campus Ap
    Posted Aug 04, 2013 08:26 PM
    Guess he knows that.. maybe he wants to use it in a enviroment that for example a hotel which  no more than 5 devices will be connected to the AP in one room...
    Sometimes clients just  dont have the budget., or they do and want to save the money.. dont know in the US but here its really hard to go agains cheapers solutions... Like Rukus or HP(specially HP its owning the market in my country... its just too cheap!), they might not do all what aruba can do but they do what they want, im talking about client point of  view.
    And thats why sometmies you came up with crazy solutions like that to compete in price hehe... but yeah its not recommended...
    You actually need to create a need! for the client of something that aruba can do that the others cant! and it has worked me though sometimes.
    Cheers
    Carlos
  • 12.  RE: Convert a RAP-2 to Campus Ap
    Posted Aug 05, 2013 04:00 PM
    yes I know that, I just need to use it for a environment no more to 1 or 2 devices will be conected to the AP in a little room.
  • 13.  RE: Convert a RAP-2 to Campus Ap
    Posted Aug 07, 2013 12:21 AM
    Sorry to add to the confusion, but as of AOS 6.1.x and higher, RAP-2WG as campus AP is deprecated - the following log message will be seen:
    Aug  7 12:06:23  stm[1567]: <305043> <WARN> |stm|  AP rap2 (type RAP-2WG) can only be used as a remote AP.
    showing unlicensed+inactive in the AP database
    (sg-3200) #show ap da
    AP Database
    Name       Group    AP Type  IP Address    Status     Flags  Switch IP
    rap2       lab      RAP-2WG  192.168.1.10  Up 3m:27s  IL     192.168.1.155
    from what I understand, there was a plan to allow it, then it was revoked by R&D. At the end of the day, RAP-2 cannot function as campus these days.
    regards
    -jeff
  • 14.  RE: Convert a RAP-2 to Campus Ap
    Posted Aug 07, 2013 11:29 AM
    this is my case when I did an upgrade in the controller and  the controller pass from 5.0.4.9 to 6.1.3.9 I lost  the Rap-2, the status of the Rap was Down.
    only as RAP it can be operated in this version (6.1.3.9)?
    Regards
  • 15.  RE: Convert a RAP-2 to Campus Ap
    Posted Aug 07, 2013 12:21 PM
    Hi chbaca
    yes, that is the case for all 6.x, the RAP-2 is locked down to RAP only. Perhaps you can consider a RAP-3 instead, as it functions fine as CAP.
    regards
    -jeff
    (sg-620) #show ap da
    AP Database
    rap3               lab-cap    RAP-3WN  192.168.1.11  Up 3m:22s             192.168.1.156
  • 16.  RE: Convert a RAP-2 to Campus Ap
    Posted Aug 07, 2013 12:25 PM
    Even though it is provisioned as a remote AP, you could still configure it
    to behave similarly to a campus AP, especially of you are using tunnel.
