Convert IAP 105
  • 1.  Convert IAP 105
    Posted Feb 18, 2014 09:17 AM
    Hi
    I can´t conver an IAP 105 to AP 105
    I log in to instant and put the ip address of my controller 10.9.4.99 and gett a message saying status not available.
    What is the problem ? IAP need to ping the controller ? IAP does not have an IP, so how is the conversion done ? Does the IAP contacts the Aruba Controller?
    I am not able to do the conversion
    My controller is 3200xm ( 6.2.0.3)  and IAP is :
    9c:1c:12:c9:08:2c# show version
    ArubaOS (MODEL: 105), Version 6.2.1.0-3.3.0.3
    Can you help ?
  • 2.  RE: Convert IAP 105
    Posted Feb 18, 2014 10:04 AM
    Yes.....IAP needs to be able to talk to the controller and needs an IP address to do so.
  • 3.  RE: Convert IAP 105
    Posted Feb 18, 2014 11:50 PM
    Please make sure that you IAP can communicate (PING) to the controller and regulatory domain of both IAP and controller are same.
  • 4.  RE: Convert IAP 105
    Posted Feb 19, 2014 05:30 AM
    IAP not getting dhcp ip address..
    I am going to try to put a static one and see if it works
  • 5.  RE: Convert IAP 105
    Posted Feb 19, 2014 11:03 AM
    OK
    Done.
    it seems that we have one switch bad.. Dhcp is on Datacenter and we pass bettween 3 floor switches.
    When i Changed to another switch everything is ok !
    Thanks for the help
  • 6.  RE: Convert IAP 105
    Posted Feb 19, 2014 11:07 AM
    IAP is converted to AP 105, but only shows 11A/N led.
    The 11 B/G/N is off. Do you know why? It only appens on one of the ap´s
    tks
  • 7.  RE: Convert IAP 105
    Posted Feb 19, 2014 11:27 AM
    Have you provisioned the AP?
    What does your SSID profile look like?  Do you you have it set to only advertise on the 5GHz radio or both?
  • 8.  RE: Convert IAP 105
    Posted Feb 19, 2014 01:27 PM
    Both..
    I test it with another ap and both leds are green
    Bruno Costa
    CONNECTing . . .
    Projectos e Consultoria Lda.
    Rua Diogo de Silves, 33C
    Restelo
    1400-107 Lisboa
    PORTUGAL
    Tlf:    +351-213031100
    Fax:  +351-213031117
    Tlm:   +351-916158228
    EMail: baraujo@connecting.pt
  • 9.  RE: Convert IAP 105
    Posted Feb 19, 2014 01:32 PM
    What version of SW is running on your controller? May need to update.
    What is the regulatory domain of your IAP?  You can see that on the white part# sticker on the back of the AP. Ex: IAP-105-US.
    What is the regulatory domain of your controller?
    What Country Code are you setting for your APs?
    Is the other, working, AP and IAP-105 or a regular AP-105?
  • 10.  RE: Convert IAP 105
    Posted Feb 19, 2014 01:40 PM
    Hi marcos
    Running 6.3 on Controller
    Both are IAP ?s running PT country code
    I?ve checked on Controller and all seem fine on the radios
    I?ve never seen but could be a led error?
    Because I see both radios UP in ap config on controller
    Bruno Costa
    IT User Support Specialist
    Information Technology
    Building Efficiency
    Tel: +351 210 940 066
    Mob: +351 916 158 228
    Fax: +351 219 598 084
    E-mail: Bruno.Costa-EXT@jci.com
    Internet: www.johnsoncontrols.com
    Johnson Controls
    Building Efficiency
    Av. do Forte, 12
    Carnaxide
    2790-072
    Portugal
    Johnson Controls Portugal BE Lda, a company registered in Portugal. Avenida do Forte, Edificio Tetrapak, Parish of Carnaxide, Oeiras, Portugal. Registered number: 505206790. For further details please click here.
    This email transmission may be confidential and is intended solely for the person or organisation to which it is addressed. If you are not the intended recipient, you must not copy, distribute or disseminate the information, or act in reliance upon it. Any views expressed in this message are those of the individual sender, except where the sender specifically states them to be the views of any organisation or employer. If you have received this message in error, do not open any attachment but please notify the sender and delete this message from your system. This email may be covered by legal, professional or other privilege. Please rely on your own virus check as no responsibility is taken by the sender for any damage arising as a result of any virus or similar infection contained herein.
  • 11.  RE: Convert IAP 105
    Posted Feb 19, 2014 01:58 PM
    It could be a regulatory domain mis-match.  If the AP is a -US model it will not come up on a -ROW controller.  It may be worth checking but you need to look at the back of the AP.
    I have not seen LEDs fail; however, if the radio is working and clients can connect it may be.  If this is the case you should open a case with TAC.
  • 12.  RE: Convert IAP 105
    Posted Feb 20, 2014 05:31 AM
    If it is a LED failure you shoudl still be able to see both radio for that AP when you do a show ap bss-table.
