  • 1.  Convert IAP 315 to CAP permanently
    Posted Mar 08, 2018 01:34 AM
    So there is this customer that would like to have their APs as CAP even after the factory restore.
    From what I've seen, the "factory restore" is actually the firmware loaded on partition 1, and it has a flag indicating "Instant preserve":
    apboot> osinfo
    Partition 1:
        image type: 0
      machine type: 40
           version: 6.5.0.0-4.3.0.0
      build string: ArubaOS version 6.5.0.0-4.3.0.0 for Hercules (p4build@rhodes) (gcc version 4.6.3 20120201 (prerelease) (Linaro GCC 4.6-2012.02) ) #56428 SMP Mon Sep 12 03:03:01 PDT 2016
             flags: Instant preserve
               oem: aruba
    How do I proceed to edit this flag? The only solution I could come up with, is writing "partition 1" with a TFTP server, which is ok for 1 AP but not practial for many like in this case.
    Is it possible to edit this flag from the CLI? Does anybody knows where is this stored?
    Thank you very much :)
  • 2.  RE: Convert IAP 315 to CAP permanently
    Posted Mar 08, 2018 04:45 AM
    unfortunately you will have to indeed use the TFTP method and overwrite the partition 1 manually in all APs if you want the CAP software to survive a reset.
  • 3.  RE: Convert IAP 315 to CAP permanently
    Posted Mar 08, 2018 06:08 AM
    I was really hoping for some weird and fun solution in full access mode. Thank you a lot.
