  • 1.  Convert IAP to Campus AP
    Posted Dec 12, 2018 03:04 PM
    Currently using 15 iAP-315 ans I'm managing them all by Airwave. I want to convert  to campus AP but when i want to do so and connect to VC ==> Maintenance ==> Convert, there is no such option. Can I convert them using Airwave?  What are the other possibilities?
  • 2.  RE: Convert IAP to Campus AP
    Posted Dec 13, 2018 11:55 AM
    I would think the easiest way is to change Airwave into read-only management mode. Then in a few minutes the Instant cluster will regain local management and you can convert the APs to campus mode via the local WebUI.
  • 3.  RE: Convert IAP to Campus AP
    Posted Dec 13, 2018 01:56 PM
    What is the best way to change Airwave into read-only management mode?
    Thanks!
  • 4.  RE: Convert IAP to Campus AP
    Posted Dec 13, 2018 06:07 PM
    In Airwave, navigate to the Virtual Controller for the swarm you want to manage from the GUI and check the "Monitor Only" box:
    And save your change. After the iAP checks in, the GUI will update to allow you to make configuration changes.
