  • 1.  Convert IAP205 to CAP error
    Posted Jul 03, 2017 10:09 AM
    Dears,
    Our customer has a misterious problem... They are trying to convert an IAP205 to a CAP. When doing this, they receive the following error:
    Error in server response, closing control connection.
    Retrying.
    Target : AP-HASSELT
    show vpn status
    profile name:default
    current using tunnel                            :unselected tunnel
    current tunnel using time                       :0
    ipsec is preempt status                         :disable
    ipsec is fast failover status                   :disable
    ipsec hold on period                            :600s
    ipsec tunnel monitor frequency (seconds/packet) :5
    ipsec tunnel monitor timeout by lost packet cnt :6
    ipsec     primary tunnel crypto type            :Cert
    ipsec     primary tunnel peer address           :N/A
    ipsec     primary tunnel peer tunnel ip         :N/A
    ipsec     primary tunnel ap tunnel ip           :N/A
    ipsec     primary tunnel using interface        :N/A
    ipsec     primary tunnel using MTU              :N/A
    ipsec     primary tunnel current sm status      :Init
    ipsec     primary tunnel tunnel status          :Down
    ipsec     primary tunnel tunnel retry times     :0
    ipsec     primary tunnel tunnel uptime          :0
    ipsec      backup tunnel crypto type            :Cert
    ipsec      backup tunnel peer address           :N/A
    ipsec      backup tunnel peer tunnel ip         :N/A
    ipsec      backup tunnel ap tunnel ip           :N/A
    ipsec      backup tunnel using interface        :N/A
    ipsec      backup tunnel using MTU              :N/A
    ipsec      backup tunnel current sm status      :Init
    ipsec      backup tunnel tunnel status          :Down
    ipsec      backup tunnel tunnel retry times     :0
    ipsec      backup tunnel tunnel uptime          :0
    end of show vpn status
    show upgrade info
    Image Upgrade Progress
    Mac                IP Address   AP Class  Status       Image Info                        Error Detail
    34:fc:b9:c2:09:a6  10.11.21.11  Taurus    downloading  ac-ftp://10.20.21.10/armv7ns.ari  Retrieve image fail
    Auto reboot           :enable
    Use external URL      :enable
    Master wait Time      :99 secs 0 count
    Switch Partition      :enable
    end of show upgrade info
    show log upgrade
    ----------Download log start----------
    Executing '/aruba/bin/download_image_swarm ac-ftp://10.20.21.10/armv7ns.ari --no-proxy X-Ap-Info:CNCKHMJ3NB,34:fc:b9:c2:09:a6,AP-205'
    fetching ('/usr/sbin/wget -T 120 -t 3 --no-proxy --header=X-Ap-Info:CNCKHMJ3NB,34:fc:b9:c2:09:a6,AP-205 -a /tmp/download_url_log ftp://sap:x@10.20.21.10/armv7ns.ari')
    --08:01:32--  ftp://sap:*password*@10.20.21.10/armv7ns.ari
               => `armv7ns.ari'
    Connecting to 10.20.21.10:21... connected.
    Logging in as sap ...
    Retrying.
    --08:03:35--  ftp://sap:*password*@10.20.21.10/armv7ns.ari
      (try: 2) => `armv7ns.ari'
    Retrying.
    --08:05:38--  ftp://sap:*password*@10.20.21.10/armv7ns.ari
      (try: 3) => `armv7ns.ari'
    Giving up.
    Error: failed to retrieve image
    cleaning up
    done
    ----------Download log end------------
    Download status: Retrieve image fail
    ----------Upgrade log start----------
    upgrade log not available
    ----------Upgrade log end------------
    Upgrade status: upgrade status not available
    end of show log upgrade
    show log rapper
    Rapper info not available
    end of show log rapper
    They can ping the controller, and even in the datapath session on the controller, I can see the FTP port 21 comming from our IAP205. The controller is also answering, but it seems that it is not received by our IAP.
    IAP is connected on a private WAN link. Is it possible that it has something to do with MTU size or something like that?
    Kind regards,
    Thomas
  • 2.  RE: Convert IAP205 to CAP error
    Posted Jul 03, 2017 11:24 AM
    Hey, what is the version  of code you are running on the controller and on the IAP? Is there any packet loss between the controller and IAP? I assume you've also whitelisted the IAP as well? (CPSec).
  • 3.  RE: Convert IAP205 to CAP error
    Posted Jul 03, 2017 11:35 AM
    Controller 6.4.4.12
    IAP: 6.4.4.8 - 4.2.4.3
    No packet loss between controller an IAP
    For now we have activated Control Plane Security with Auto-cert provisioning and all addressess allowed for Auto Cert. (no limitations) but still not working
  • 4.  RE: Convert IAP205 to CAP error
    Posted Jul 03, 2017 12:41 PM
    You should try opening up an FTP window from a client on the AP's subnet to the controller and see if it asks for a username and password:
    ftp
    ftp> open <ip address of controller>
    connected to 192.168.1.20
    220 FTP server ready
  • 5.  RE: Convert IAP205 to CAP error
    Posted Jul 05, 2017 04:15 AM
    Hi cjoseph,
    we receive the expected output from the ftp; it is asking for username and password.
    So ftp is not blocked.
  • 6.  RE: Convert IAP205 to CAP error
    Posted Jul 05, 2017 09:09 AM
    There seems to be a problem with the login portion of the conversion.  Is there a firewall between the IAP and the controller?  Regardless of the answer, you probably should open a TAC case to get to the bottom of it.  Below is what a normal conversion looks like.
    Executing '/aruba/bin/download_image_swarm ac-ftp://10.2.100.20/armv7ns.ari --no-proxy'
    fetching ('/usr/sbin/wget -T 120 -t 3 --no-proxy -a /tmp/download_url_log ftp://sap:x@10.2.100.20/armv7ns.ari')
    --21:05:09--  ftp://sap:*password*@10.2.100.20/armv7ns.ari
               => `armv7ns.ari'
    Connecting to 10.2.100.20:21... connected.
    Logging in as sap ... Logged in!
    ==> SYST ... done.    ==> PWD ... done.
    ==> TYPE I ... done.  ==> CWD not needed.
    ==> PASV ... done.    ==> RETR armv7ns.ari ... done.
        0K .......... .......... .......... .......... ..........   52.78 KB/s
       50K .......... .......... .......... .......... ..........  256.68 KB/s
  • 7.  RE: Convert IAP205 to CAP error
    Posted Jul 05, 2017 09:50 AM
    I think it has something to do with MTU, If I convert the IAP to RAP, it works without any issue.
    The link is over a private WAN link that is provided by one of the big telecom providers in BE. I think it is MTU related, since RAP is using 1200bytes via port 4500 while the CAP is using 1500 in his initial connection to the controller via FTP, if I am not mistaking?
