  • 1.  Converting AP 105 to IAP 105 ?
    Posted Jun 07, 2012 08:58 AM
    How do I do that?
  • 2.  RE: Converting AP 105 to IAP 105 ?
    Posted Jun 07, 2012 09:20 AM
    AFAIK, you can't.  You can convert an IAP-105 to an AP-105 (and then back to an IAP, if you want), but an AP that started life as an AP-105 can't ever be an IAP.
  • 3.  RE: Converting AP 105 to IAP 105 ?
    Posted Jun 07, 2012 09:50 AM
    No conversion possible from AP 105 to IAP 105 due to regulatory restrictions.
    Shashi
  • 4.  RE: Converting AP 105 to IAP 105 ?
    Posted Jun 12, 2013 05:39 PM
    Just curious, what are the Regulatory Restrictions? difference between AP and IAP seems to be all software.
  • 5.  RE: Converting AP 105 to IAP 105 ?
    Posted Feb 21, 2014 09:29 AM
    I believe this refers to the different WLAN channels you can use in different areas of the world.
  • 6.  RE: Converting AP 105 to IAP 105 ?
    Posted Aug 08, 2012 09:08 AM
    So how do you convert an iap that is a rap back to iap?
  • 7.  RE: Converting AP 105 to IAP 105 ?
    Posted Sep 26, 2012 05:54 PM
    Factory reset by holding the reset button while turning it on.
  • 8.  RE: Converting AP 105 to IAP 105 ?
    Posted Feb 21, 2014 08:56 AM
    It does not work
