Cloud Managed Networks
  • 1.  Converting CAP AP to ap managed with central with aruba os 10
    Posted May 16, 2023 06:49 PM
    Hello
    If i have a controller with mobilty master
    i want to convert a 325 CAP to aruba central with aruba os 10
    I understant that  i can upgrade it, the documentation says that if it does not start with DD  then it works
    Or im wrong in this part?
    The orther question
    if for some reason i need to convert back my AP 325 that is now with aruba os 10 on the cloud to Aruba os 8 managed by the controllers and the mobility master it is possible? or its a one way convertion?
    If its possible how you can do it?
  • 2.  RE: Converting CAP AP to ap managed with central with aruba os 10
    Posted May 16, 2023 07:12 PM
    you can refer to AOS10 Adoption guide
    yes you can convert AP-325 to run AOS10 and be managed by Aruba Central.
    you can also revert back to controller based AOS8 from AP-325 that was converted to AOS10. just ensure the target controller has adequate AP licenses.
  • 3.  RE: Converting CAP AP to ap managed with central with aruba os 10
    Posted May 16, 2023 07:42 PM
    So to revert it back i take out the license of the aruba central for that AP.  And it will act like a normal AP with Aruba os8 and will download the firmware from the controllers with the ADP  if i connect it on the same vlan of the controllers?
    Im just trying to understand
    What i said  up there is not totally true as i can see because it do have the aruba OS firmware but what i can do is take downt the license, and maybe try to delete it?
    Or i don tknow if a factory reset could work?
    In my example the controller has all the license for that AP to recive it.  I just want to know the procedure for the rollback of the AP of Aruba OS 10 to Aruba OS 8 is correct.
  • 4.  RE: Converting CAP AP to ap managed with central with aruba os 10
    Posted May 16, 2023 08:22 PM
    to revert back to Campus AOS8 is basically to get access to the console of the AP and type a command to convert t back (can't remember the exact commad)
    once that is done, then remove the Aruba Central AP subscription.
  • 5.  RE: Converting CAP AP to ap managed with central with aruba os 10
    Posted May 17, 2023 05:19 AM
    CLI command on Instant or AOS10 AP to convert to a controller would be:
    convert-aos-ap cap 192.168.31.16
    ... where 192.168.31.16 is the IP address of your controller. The AP will connect to the controller, download campus AP firmware and reboot. It probably will set the 'master-ip' as well, so ADP or other controller discovery is by-passed. Instead of 'cap' as second statement, also 'rap' can be used to convert to a Remote AP connected to the same controller.
  • 6.  RE: Converting CAP AP to ap managed with central with aruba os 10
    Posted May 17, 2023 09:10 AM
    Thanks Herman, Ariyap for your support
    I was worried i coud not revert back and also that i could not transform a CAP to be managed by central but it seems you can now Converting APs to Instant APs (arubanetworks.com)
  • 7.  RE: Converting CAP AP to ap managed with central with aruba os 10
    Posted May 25, 2023 10:48 AM
    That is correct. Some (competitors) claim that there is a one-direction conversion with Aruba, but you can switch between Instant - CAP - RAP - AOS10 mode as long as the AP support it. Just conversion of an Campus AP product (which is only available for the AP 1xx-3xx series, so the APs without country code) to Instant mode is not officially supported (but sometimes seem to work nevertheless). The conversion method that you found is just supported to convert Campus AP to AOS 10.
