Converting IAP 105 to a AP 105
Deltr0nz
Deltr0nzJul 22, 2013 03:24 PM
Deltr0nz
Deltr0nzJul 22, 2013 04:01 PM
  • 1.  Converting IAP 105 to a AP 105
    Posted Jul 22, 2013 03:24 PM
    Can someone tell me how to do this?
  • 2.  RE: Converting IAP 105 to a AP 105
    Posted Jul 22, 2013 03:46 PM
    Sure!  You login to the Instant UI:
    1. Click on Maintenance in the top right
    2. Click on the Convert Tab
    3. Click on the selection to convert to a CAP (Campus AP)
    4. Enter the IP address of the controller you wish to terminate to
    That's it!  If you'd like to convert BACK to an IAP, then simply issue a hardware reset (paperclip on the bottom of the unit).
  • 3.  RE: Converting IAP 105 to a AP 105
    Posted May 07, 2015 04:06 AM
    Hi..
    i'm trying to convert IAP to campus ,, but it dosen't work !
    i connect IAP dircetly to (PoE) network and when i press vonvert not it says (status not available)
    plz help me
  • 4.  RE: Converting IAP 105 to a AP 105
    Posted May 07, 2015 04:29 AM
    I think this is related with image versions...
    In order to convert an IAP to RAP, Controller should have minimum 6.1 Image version and also there is a minimum 4.1 IAP version
    Regards
  • 5.  RE: Converting IAP 105 to a AP 105
    Posted May 07, 2015 09:36 AM
    thanks alot
  • 6.  RE: Converting IAP 105 to a AP 105
    Posted May 07, 2015 09:47 AM
  • 7.  RE: Converting IAP 105 to a AP 105
    Posted May 07, 2015 09:55 AM
    Did you disable Terminal Access?
    Make sure it is enabled:
  • 8.  RE: Converting IAP 105 to a AP 105
    Posted May 07, 2015 10:08 AM
  • 9.  RE: Converting IAP 105 to a AP 105
    advance option .. yes its enabled
  • 10.  RE: Converting IAP 105 to a AP 105
    Posted May 24, 2015 10:25 AM
    then there is a good chance something is blocking your ssh access in between client and IAP. are they in the same network?
    but still even with the GUI you can convert, look at the 2nd post.
  • 11.  RE: Converting IAP 105 to a AP 105
    Posted May 24, 2015 03:27 PM
    If you have access to the serial-console of the IAP you can also try:
    1) Connect serial console
    2) Power up AP
    3) Press <ENTER> to interupt the boot (and enter AP-boot)
    4) For AP-105, type: upgrade os 1.1.1.1:mips32.ari (where 1.1.1.1 is the IP of the controller)
    5) After the image is loaded, type: boot
    For this to work TFTP should be allowed towards the controller.
    The AP should fine the controller, presuming the AP is either in the same L2 domain as the controller or if a DNS record for "aruba-master.DNS-SUFFIX" is present. If not available you could set a variable for the controller via "setenv master 1.1.1.1" in AP-boot.
  • 12.  RE: Converting IAP 105 to a AP 105
    Posted Sep 21, 2017 11:18 AM
    Saludos
    Presento el mismo problema pero con IAP 207, no me deja convertir a AP y me presenta error de version de imagen.Que debo hacer y como lo puedo hacer.
    Muchas Gracias
  • 13.  RE: Converting IAP 105 to a AP 105
    Posted May 07, 2015 07:23 AM
    Make sure the IAP can communicate with the controller. SSH to the IAP and try pinging the controller.
  • 14.  RE: Converting IAP 105 to a AP 105
    Posted Jul 22, 2013 04:01 PM
    Perfect. Thank you
  • 15.  RE: Converting IAP 105 to a AP 105
    Posted Feb 18, 2014 08:30 AM
    Hi Guys
    I tried that to conver an IAP 105 to CAP and says status not available and no conversion occurs.
    Do you know why?
    Regards
  • 16.  RE: Converting IAP 105 to a AP 105
    Posted Feb 18, 2014 11:49 PM
    Make sure that IAP and controller both have same regulatory domain.
  • 17.  RE: Converting IAP 105 to a AP 105
    Posted Apr 20, 2017 12:53 PM
    We had the same problem. Our DHCP server was getting an error and was giving to the Aruba AP an address which was being used by other device. We exclude this address on the dhcp server, reset the AP and everything worked fine. You can also try configure a static IP address in the AP.
