Hi experts,
My customer has some branches with RAPs, but recently the branches have direct connectivity with the central office, so they want to convert their RAPs to CAPs.
I have read some posts about converting CAP to RAP, but there aren't about convertig RAP to CAP.
I think for converting these RAPs to CAPs I will need to follow the below steps:
- Click on Configuration > Wireless > AP Installation and select the AP I want to convert. Click on Provision.
- If the RAP is in split-tunnel mode, a new AP group without split-tunnel policies will be needed.
- Change Remote AP from Yes to No.
- In the Master Discovery section, better to select Host Controller Name and let the AP discover the controller by DHCP/DNS.
- In the AP settings, better to select Obtain IP Address Using DHCP and avoid the cumbersome of asigning IP addresses statically.
- Click on Apply and Reboot.
Here a screenshot:
Are the above steps correct? Could you confirm please?
Julián
