I'm new to the Aruba MAS and am looking to figure out whether there is an equivalent to the cisco-ish
"copy flash: <file> running-config" command which takes a flash file and essentially pastes it as though
it were typed at the CLI, with some sensible special behavior surrounding anything interactive. Note for
those unfamiliar with Cisco, this command does NOT erase anything that is in the running-configuration.
That's my general question. This is my more specific question:
It was my hope that I would be able to use such a thing to paste mgmt-user entries into the configuration,
since the CLI does not allow you to enter the crypt, nor even enter the password non-interactively. I need
to be able to paste other employees' passwords into the switch config without seeing the cleartext
password. The same question applies to various aaa secrets and keys. Though you can paste these in
non-interactively, the password is set to the crypt, not to the original value. Under most other cisco-like
systems one precedes the crypt with a number designating what kind of crypt is being entered (or cleartext).
This syntax seems not to be accepted on the MAS.
What do other Aruba users do to acheive equivalent functionality?
