Comware
copy startup config from a usb to switch
  • 1.  copy startup config from a usb to switch
    Posted Apr 27, 2010 12:47 PM
    Hi all,
    Is it possible to copy a switch config from a USB to an active running config for disaster recovery purposes?
  • 2.  RE: copy startup config from a usb to switch
    Posted Apr 27, 2010 02:30 PM
    You cannot copy a config to the running/active config.
    You can copy from the usb to the startup config position:
    'copy usb startup-config <FILENAME>'
    then reload the switch and your config will be running.
    hth...Jeff</FILENAME>
