Hi
Use the Command :
SW(config)#copy tftp flash a.b.c.d filename.swi primary
Where:
a.b.c.d is your TFTP server.
filename is the flash file name that you downloaded from ProCurve Web site.
If you want to copy to the Secondary image then use the option: Secondary
Then boot from the secondary image file by using the command:
Sw(config)#boot system flash secondary
Good Luck !!!
