Correct argument to match computed integer attribute.
  • 1.  Correct argument to match computed integer attribute.
    Posted Oct 10, 2013 05:25 AM
    Hi ,
    What is the correct format to allow this integer attribute to match to computed attribute?
    example
    Computed attribute = set to integer
    allowed = set to integer
    Role Mapping
    Auth:test_allowed allowed equals 2
    because using an integer number 2 will work can be detect by the clearpass to allow only two device  but when using %{} and match it to the computed attribute would allow everything.
  • 2.  RE: Correct argument to match computed integer attribute.
    Posted Dec 16, 2013 05:48 PM
    What are you trying to do?
