  • 1.  could I integrate Clearpass with Cisco Wireless?
    Posted Jul 29, 2016 11:12 AM
    so we have a clearpass installed with a Aruba Wireless solution, so the thing is what about clearpass with cisco wireless integration?
    Regards!
    hope your coments..
  • 2.  RE: could I integrate Clearpass with Cisco Wireless?
    Posted Jul 29, 2016 11:14 AM
    Yes you can. Have you reached out to your ClearPass partner?
  • 3.  RE: could I integrate Clearpass with Cisco Wireless?
    Posted Jul 29, 2016 03:08 PM
    Yes they same that we can integrate it, but don't respond to me if exist a limitation with some Cisco models.
    so exist a limitation with cisco models?
  • 4.  RE: could I integrate Clearpass with Cisco Wireless?
    Posted Jul 29, 2016 04:12 PM
    Yes, you need to look at the features support matrix on Cisco.com to see in
    what release they added certain features. Which features depends greatly on
    what you're trying to do.
  • 5.  RE: could I integrate Clearpass with Cisco Wireless?
    Posted Jul 29, 2016 04:14 PM
    Thanks!
  • 6.  RE: could I integrate Clearpass with Cisco Wireless?
    Posted Jul 31, 2016 01:25 PM
    Having worked on Cisco wireless previously and now clear pass and Aruba wireless it should work depending on what you want it to do? Clear pass works with Cisco switches no problem and can do radius 802.1x and tacas+ as I have not integrated the two sadly do not have any more information
