  • 1.  CP with AD auth to multi forest trust
    Posted Sep 04, 2024 10:45 AM
    Hi all,
    I'm not sure if what I'm trying to do is a valid design and need some assistance. We are building a secure environment and have a dedicated clear pass server that talks to this new secure.local domain. the domain/forest has a trust with user.local forest and we would like to have a group in secure.local with individual users from user.local. so far so good.
    we can authenticate with a user that is part of secure.local but not with any users that are from user.local in the same group.
    I'm doing a GC query on port 3268 and can browse AD will this work?
  • 2.  RE: CP with AD auth to multi forest trust
    Posted Sep 04, 2024 07:07 PM
    Been a really long time since I've had to look at a multi-forest setup.
    Double check the trust relationship is of the correct type.
    What kind of authentications are you going to be using?
    Something to look at:  https://community.arubanetworks.com/community-home/librarydocuments/viewdocument?DocumentKey=b0fb0082-e715-4014-8370-dbba08115aef&CommunityKey=3dd64143-3ac3-4152-9abd-06dc0b4ecdd1&tab=librarydocuments
    Carson Hulcher, ACEX#110
  • 3.  RE: CP with AD auth to multi forest trust
    Posted Sep 05, 2024 06:19 AM
    thanks,
    when you say correct trust relationship type. you mean eg: one way, transitive...etc? and Auth to LDAP is none at the moment while i try and get this working.
  • 4.  RE: CP with AD auth to multi forest trust
    Posted Sep 05, 2024 10:58 AM
    Probably best off opening a case with TAC to troubleshoot what you've got.
  • 5.  RE: CP with AD auth to multi forest trust
    Posted Sep 06, 2024 03:49 AM
    What is your authentication method?
    The LDAP/Global Catalog is just for authorization information, and if you want to do PEAP-MSCHAPv2 (DEPRECATED!!!!!) you would need to join the individual domains.
    If you can share the output of Access Tracker for one working and one non-working user, most specific the Alerts tab, that may provide an indication of what's going on.
