The certificate enrolled to your device should have the Intune Device ID as Subject-CN:
This is how that looks like if you request the client certificate through Intune.
Based on the username, ClearPass cannot request the Intune information.
Original Message:
Sent: Dec 18, 2023 04:01 AM
Subject: CPPM 6.10 & InTune Extension V6
Hi dudes,
We are woring on a brand new project integrating CPPM with InTune extensión, V6. We are having some problems after configuring Authrntication source as we are having "Clearpass intune : HTTP attribute query returned error=404".
The filter query is as following the integration documentation "%{Certificate:Subject-CN}" and every single time the same alert on Access Tracker.
The certificate issued is for username, nothing about machine, nor devide ID.
Any suggestion about how to fix that problem? I am not used to use variables so any help would be appreciate.
Regards
JoseMi
JoseMi Cruz
