Hello
I am trying to get COA working with Aruba switches.
Getting error: Radius [ArubaOS Switching - Terminate Session] failed for client
I saw time and NTP settings could be a problem, but this is correct. Time is current and the units are using the same NTP server.
When debugging the Aruba 2530 switch, I see the following when the COA packet are sent to it:
0016:02:58:40.63 RAD tRadiusR:DISCONNECT REQUEST id: 75 from 10.0.0.34 DROPPED,
Event-Timestamp Attribute is either missing or is not current.
I can see the Timestamp Attribute in the COA action, so it seems to be there. Logic then says the time is wrong, but its correct.
Any tips.
