  • 1.  CPPM Hardware C3000
    Posted Feb 12, 2020 02:39 PM
    Hello everyone,
    I have 4 CPPM in a DC not local to me and I've been told that those 4 CPPM have only one power supply - they should have dual.
    Question - is there a way/command to check how many power supplies are currently installed in CPPM either via CLI or GUI?
    MLGG
  • 2.  RE: CPPM Hardware C3000
    Posted Feb 12, 2020 04:51 PM
    Hi MLGG,
    Good question. The redundant power supply of a C3000 hardware appliance is a optional part in the order guide or datasheet.
    https://www.arubanetworks.com/assets/ds/DS_ClearPass_PolicyManager.pdf
    I dont known if there is any CLI/GUI command to check that rather then error event in the event viewer. But you can always raise a TAC case so they can check it for you from the closed linux CLI. TAC is friendly and fast to assist you on this.
  • 3.  RE: CPPM Hardware C3000
    Posted Feb 22, 2020 11:01 AM
    thank you mkk, that's a good point.  I will follow-up with TAC.
