CPPM: Migrate from EAP-MSCHAPv2 to EAP-TLS
This thread has been viewed 41 times
  • 1.  CPPM: Migrate from EAP-MSCHAPv2 to EAP-TLS
    Posted Aug 03, 2023 04:11 PM
    Howdy,
    We are currently running Windows 10 and using CPPM to perform 802.1X on our WIRED ports for both user and computer accounts. The access switch is a 6300M. Our Windows 10 clients are using EAP-PEAP, EAP-MSCHAPv2.
    In testing Windows 11 we have found that this no longer works and are forced to change to a more secure and modern method of EAP-TLS.
    We have created a test service to only use EAP-TLS in CPPM and manually added the test Windows 11 machine to the policy and everything works as it should.
    The challenge we are facing, and can't seem to find a solution, is how we can target this policy to only Windows 11 machines we are replacing as we don't want to change the Windows 10 machines. Was hoping to use an AD group attribute, but don't see that as an option. Does anyone have any ideas?
    Thanks in advance
  • 2.  RE: CPPM: Migrate from EAP-MSCHAPv2 to EAP-TLS
    Posted Aug 03, 2023 09:08 PM
    Use static host list to enlist all the Win11 machines MAC address and create separate policy based on EAP-TLS
    Use Connection:Client-Mac-Address BELONGS_TO_GROUP [Static Host List group]
  • 3.  RE: CPPM: Migrate from EAP-MSCHAPv2 to EAP-TLS
    Posted Aug 08, 2023 02:00 PM
    Thanks. Will consider this option.
  • 4.  RE: CPPM: Migrate from EAP-MSCHAPv2 to EAP-TLS
    Posted Aug 04, 2023 02:31 AM
    Hi
    As mentioned the static host list will for sure work, but the static hosts lists are mostly left in ClearPass due to backward compatibility. The user interface for the static host list is quite user unfriendly, in my opinion. The entries are added in cronological order and it's not possible to search in the list.
    Why not have both EAP-PEAP and EAP-TLS in the same service? Eventually you need to modify the AD search query to search for both sAmAccountName and UPN, but if the only difference is the authentication method I would recommend having only one service.
    The reason why you can't utilize an AD attribute is that the AD information is read after the actual authentication has taken place. You can also add a custom attribute to the Endpoints repository if you would like to have two services. Endpoints repository is searchable but depending on your administrative delegation of rights the static host list can be a better option if you need to delegate the right to add MAC addresses to a person who is not familiar with ClearPass and you would like to limit the damage they can do.
    Best Regards
    Jonas Hammarbäck
    MVP 2023, ACCX #1335, ACX-Network Security, Aruba SME, ACMP, ACDP , ACEP, ACSA
    Aranya AB
  • 5.  RE: CPPM: Migrate from EAP-MSCHAPv2 to EAP-TLS
    Posted Aug 08, 2023 02:01 PM
    I will need to also change GPO options when switching to EAP-TLS. I didn't want to mess with anything the way it is now. Was hoping to have both operating in parallel.
  • 6.  RE: CPPM: Migrate from EAP-MSCHAPv2 to EAP-TLS
    Posted Aug 08, 2023 03:00 PM
    You can have EAP-TLS and EAP-PEAP in the same service in CPPM, so you can manually move PCs that you want to migrate to a parallel GPO that does (1) autoenrollement and (2) configures the wireless to use EAP-TLS.
  • 7.  RE: CPPM: Migrate from EAP-MSCHAPv2 to EAP-TLS
    Posted Aug 04, 2023 02:47 AM
    Probaby the username sent for a certificate authentication is the UPN or E-mail (depending on the certificate configuration). What you could do is create your EAP-TLS service just above the legacy service and in the service conditions add 'IETF:Username ENDS_WITH @yourdomain.local' (must match all). That just depends on the username being different, and users on windows 10 not signing in with their UPN, but it may work.
  • 8.  RE: CPPM: Migrate from EAP-MSCHAPv2 to EAP-TLS
    Posted Aug 11, 2023 02:14 PM
    I think in Windows 11 Credential Guard is on by default.
    This will break EAP-PEAP, EAP-MSCHAv2 authentication as CG doesn't allow for the NTLM credentials to be shared.
    You can temporarily disable Credential Guard if you wish to but yourself time to get prepared for EAP-TLS. This can be done via Group Policy.
    We are in the early stages of testing Windows 11 and discovered. We disabled CG to allow us to continue testing and begin planning migrating to EAP-TLS.
  • 9.  RE: CPPM: Migrate from EAP-MSCHAPv2 to EAP-TLS
    Posted Aug 14, 2023 08:16 AM
    We also went through the process of disabling CG in out initial testing.
    Cheers
  • 10.  RE: CPPM: Migrate from EAP-MSCHAPv2 to EAP-TLS
    Posted Aug 14, 2023 08:14 AM
    Hi All,
    I was able to add EAP-TLS to my existing service. I also adjusted my AD filter. Now both Win10 and Win11 and authenticating wired connections.
    Thanks!
