Become a Member
Hi all,
I am trying to apply cumulative patch on 6.3, but after applying its continuously showing restart needed.
However i have restarted the VM saveral times..
plz give me some suggestion.
Is this the least i can do ?
For a proble of this nature it MAY likely require under-the-cover work. My strong reccomendation is that you raise a TAC case.
thanks,
tommorrow I'll open.
