Mobility Controller(MODEL: Aruba7010-JP Version 8.7.1.7)のログ(show log system all)を見たところ
「Resource 'Controlpath CPU' has exceeded」が終日(休業時も)出続けている状態となっています。
Jan 1 01:14:06 nanny[3350]: <399838> <3350> <WARN> |nanny| Resource 'Controlpath CPU' has exceeded 45% threshold (actual:50%).
Jan 1 01:15:06 nanny[3350]: <399838> <3350> <WARN> |nanny| Resource 'Controlpath CPU' has dropped below 45% threshold (actual:6%).
Jan 1 05:13:05 nanny[3350]: <399838> <3350> <WARN> |nanny| Resource 'Controlpath CPU' has exceeded 45% threshold (actual:46%).
Jan 1 05:14:05 nanny[3350]: <399838> <3350> <WARN> |nanny| Resource 'Controlpath CPU' has dropped below 45% threshold (actual:7%).
Jan 1 12:44:57 nanny[3350]: <399838> <3350> <WARN> |nanny| Resource 'Controlpath CPU' has exceeded 45% threshold (actual:62%).
Jan 1 12:45:58 nanny[3350]: <399838> <3350> <WARN> |nanny| Resource 'Controlpath CPU' has dropped below 45% threshold (actual:5%).
Jan 1 14:15:20 nanny[3350]: <399838> <3350> <WARN> |nanny| Resource 'Controlpath CPU' has exceeded 45% threshold (actual:52%).
Jan 1 14:16:20 nanny[3350]: <399838> <3350> <WARN> |nanny| Resource 'Controlpath CPU' has dropped below 45% threshold (actual:5%).
Jan 1 21:15:04 nanny[3350]: <399838> <3350> <WARN> |nanny| Resource 'Controlpath CPU' has exceeded 45% threshold (actual:47%).
Jan 1 21:16:04 nanny[3350]: <399838> <3350> <WARN> |nanny| Resource 'Controlpath CPU' has dropped below 45% threshold (actual:11%).
また、時々ですが「Resource 'Datapath CPU' has exceeded」も出ているようです。
Jan 12 09:11:39 fpapps[3469]: <399838> <3474> <WARN> |fpapps| Resource 'Datapath CPU 7' has exceeded 60% threshold (actual:99%).
Jan 12 09:13:39 fpapps[3469]: <399838> <3474> <WARN> |fpapps| Resource 'Datapath CPU 6' has exceeded 60% threshold (actual:85%).
Jan 12 09:56:43 fpapps[3469]: <399838> <3474> <WARN> |fpapps| Resource 'Datapath CPU 6' has dropped below 60% threshold (actual:50%).
Jan 12 10:00:43 fpapps[3469]: <399838> <3474> <WARN> |fpapps| Resource 'Datapath CPU 7' has dropped below 60% threshold (actual:43%).
この状態で運用を続けても問題ないでしょうか。対処すべき事項などありましたらご教示いただけないでしょうか。
