What equipment do you have? AP type? AP mode? Controller? Aruba Central?
Is this about the switch configuration? Or the AP configuration?
If this is about Instant Access points, you would configure your switch to have untagged VLAN2 on the port facing the AP, and have VLANXX and VLANYY tagged to the same port facing the AP. Then in your configuration, for management do nothing. For the clients, configure the VLANXX on the SSID/Wireless Network; and VLANYY on another SSID/Wireless Network. If a VLAN is assigned to a wireless network (or during authentication with a RADIUS server the Aruba-User-VLAN is returned with a VLAN ID), that client's traffic is automatically sent out tagged from the AP.
Original Message:
Sent: Nov 21, 2022 07:52 PM
Subject: Create multiple VLAN for AP
how do i create multiple VLAN for APs ?
i need to create 3-4 VLAN for my aruba APs, eg. VLAN2 for management, VLANXX for clients, VLANYY for clients.
