  • 1.  Create P2P connection via IAP 175
    Posted Oct 06, 2015 08:56 AM
    Does anyone have the configuration guide for P2P connection with 2 IAP-175 ap.
  • 2.  RE: Create P2P connection via IAP 175
    Posted Oct 06, 2015 09:05 AM
    - First connect both IAPs in the same Layer 2 segment (wired), disable Extend SSID.
    - Once they form a cluster you can unplug the IAP that will acting as the Mesh Point
    - Then just provide power to the Mesh point not a network connection and if is able to see the Mesh portal (backhaul iAP) it should be able to form the mesh link automatically no additional configuration.
  • 3.  RE: Create P2P connection via IAP 175
    Posted Oct 06, 2015 10:36 AM
    i have tried to do the config you have given. Buut im not able to see the second AP. Also im seeing CLI msg "someone else thinks its the master"
  • 4.  RE: Create P2P connection via IAP 175
    Posted Oct 06, 2015 10:47 AM
    What have you tried ?
    Were able to see both IAPs form a cluster first ?
    Make sure you use E0 on each IAP not E1 .
  • 5.  RE: Create P2P connection via IAP 175
    Posted Oct 06, 2015 11:55 AM
