  • 1.  Create second PSK for one SSID with differend Vlan assignment
    Posted Jan 30, 2025 02:43 AM
    on some sites i have Aruba (virtual controller) and other sites i have Unifi AP.
    Unifi has de ability to ad a second PSK to one SSID en select the Vlan that the clients gets when using this PSK.
    It takes 5 seconds to set this up.
    I am looking for the same thing on Aruba AP, not using Radius/clearpass , per device password, etc ... so simple adding second PSK on existing SSID.
    Some devices of our education must go to different Vlan, to minimize all de SSID broadcasting I prefer to not using more than the 4 recommended SSID broadcasting.
    Is this possible ?
  • 2.  RE: Create second PSK for one SSID with differend Vlan assignment
    Posted Jan 30, 2025 02:47 AM
    What you are looking for is Local Multiple PSK, at the bottom of this documentation page, which may only configurable through the CLI (not sure).
  • 3.  RE: Create second PSK for one SSID with differend Vlan assignment
    Posted Jan 31, 2025 04:28 AM
    With examples Aruba CLI Bank.
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2024
  • 4.  RE: Create second PSK for one SSID with differend Vlan assignment
    Posted Feb 04, 2025 08:34 AM
    Thanks for the info,
    If I open a SSH to the instant I get the AP prompt, not the Instant prompt... I think this is ok ?
    I created a wlan-mpsk-local example_profile with the optional "role" parameter (role i created in the Gui with a Vlan assignment).
    How do I connect with SSH to the Instant Virtual controller (running on one AP).
    Second, I do not find a step by step adding a SSID, what should i choose under the VLAN step and Access step ?
    Someone can show me step by step instruction pleas ?.
  • 5.  RE: Create second PSK for one SSID with differend Vlan assignment
    Posted Feb 06, 2025 03:55 AM
    For everyone i found a detail link how to set this up !
    https://dannytsang.com
    With thanks to the author !
