the API get the level of the account, i think it is better to create an account with only Read Only and generate the API key
and also if you are using only GET API, there is no issue
PowerArubaCL: Powershell Module to use Aruba Central
ACEP / ACMX #107 / ACDX #1281
Original Message:
Sent: Dec 27, 2024 11:14 AM
Subject: Creating a read-only API session -Aruba Central
Forgive me I am new to the world of APIs, I have been working in Postman with the Aruba Central API but I want to be sure that I do not accidentally update any settings in Central. I assumed when I created my token in central there would be options for access level but I do not see any. How would I go about logging into central via the API with read access only?
