  • 1.  CRL distribution to ClearPass subscribers
    Posted Feb 11, 2019 01:13 PM
    Hi
    A customer with a ClearPass cluster with five nodes experienced some authentication issues due to a Publisher failure.
    The problem was that during the failure of the Publisher one CRL from the internal PKI expired and the Subscribers didn´t downloaded a fresh CRL from the CRL distribution point.
    Should the CRL be downloaded by each node in the cluster or the Publisher and then distributed to the Subscribers?
    The CRL is configured to be downloaded every hour, but from what I have seen it's only downloaded when the CRL expires.
    Shouldn't the option to download the CRL every hour force a download of the CRL regardless if it has changed or not?
    In this case the CRL have 14 days validity time and are issued one a week. But the new CRL isn't downloaded even though a new is available.
    The cluster is running on ClearPass 6.6.8 on CP-HW-25K and upgrade to 6.7.x is in the pipeline.
  • 2.  RE: CRL distribution to ClearPass subscribers
    Posted Feb 11, 2019 02:34 PM
    You should consider moving to OCSP but if not possible then use a standby Publisher
    >From the user guide :
    https://www.arubanetworks.com/techdocs/ClearPass/Aruba_DeployGd_HTML/Content/Cluster%20Deployment/Standby_publisher.htm
    Functions Lost When the Publisher Is Down
    When the active Publisher goes out of service, the following ClearPass Policy Manager functions are temporarily lost:
    AirGroup and MACTrac enrollment
    Certificate creation and revocation
    Certificate revocation list updates
    ClearPass Exchange outbound enforcement
    General ClearPass Policy Manager and ClearPass Guest configuration changes
    ClearPass Guest account creation
    Mobile device management endpoint polling and ingestion
    Onboarding functionality
    Not sure if this functionality exist in 6.6 but in 6.7 you can set the CRL to get updated in a certain of time
    Sent from Mail for Windows 10
  • 3.  RE: CRL distribution to ClearPass subscribers
    Posted Feb 11, 2019 02:49 PM
    Thank you for the information.
    In this case there was a standby Publisher configured but for some reason the failover failed.
    Why this happend is something we will investigate further.
