  • 1.  Crypto pki-import fail / WebUI not working
    Posted Dec 21, 2016 03:52 AM
    Hi , I'm trying to apply openssl cert using CLi to wlc running 6.2.1.4.
    Crypto pki-import pem servercert wlc1 sert.pem "password"
    Result : Error, out of space
    Sh mem : tot 659204, used 412248, free 246596
    At the same tume controller WebUI doesn't work. Login page opens but after that blank screen. HTTPD process has been restarted but no go.
    Br
    Juha-Pekka
    #ALE
  • 2.  RE: Crypto pki-import fail / WebUI not working
    Posted Dec 21, 2016 06:41 AM
    How did you end up in this situation?  What broke the WebUI?
  • 3.  RE: Crypto pki-import fail / WebUI not working
    Posted Dec 21, 2016 06:55 AM
    Okay, if the GUI is broken, you can revert to the built-in certificate by doing this:
    (Aruba7005-US) #restore ?
    factory_default         factory default setting
    flash                   untar and uncompress to restore the flash's
                            important directories from flashbackup.tar.gz
    (Aruba7005-US) #restore factory_default ?
    certificate             Revert the current default certificate to factory
                            default certificate
    (Aruba7005-US) #restore factory_default certificate ?
    <cr>
  • 4.  RE: Crypto pki-import fail / WebUI not working
    Posted Dec 22, 2016 05:38 AM
    Done,
    (WLC-1) #show crypto-local pki ServerCert
    Certificates
    Name            Original Filename  Reference Count  Expired
    (WLC-1) #
    HTTPD restarts itself, but WebUI still not opening
    Login window opens fine, and login is fine, but then Blank screen
    This problem remains
    (WLC-1) #crypto pki-import pem ServerCert wlc-1 wlc_self_cert.pem "password"
    Error, out of space
    I've asked service window to boot WLC or do You have other proposals?
    Br
    Juha-Pekka
  • 5.  RE: Crypto pki-import fail / WebUI not working
    Posted Dec 22, 2016 05:42 AM
    Try clearing your browser cache or use another browser.
  • 6.  RE: Crypto pki-import fail / WebUI not working
    Posted Dec 22, 2016 07:06 AM
    Sure, I always start browser after httpd restart (close it)
    Firefox Winfows machine + Safari MAC, no go
    TAB Shows : Monitoring but no go, blank screen
    Juha-Pekka
  • 7.  RE: Crypto pki-import fail / WebUI not working
    Posted Dec 22, 2016 07:12 AM
    Safari gives more information
  • 8.  RE: Crypto pki-import fail / WebUI not working
    Posted Dec 22, 2016 08:46 AM
    I have not seen that before.  You might want to open a TAC case, or schedule a maintenence window to reboot.
  • 9.  RE: Crypto pki-import fail / WebUI not working
    Posted Dec 22, 2016 09:09 AM
    Thanks. Reboot first step
    Br
    Juha-Pekka
