I tried your script but it looks for the private key that is not present, obviously, since the CSR has been generated on the Switch itself
POST EDIT.
Original Message:
Sent: Jul 07, 2023 09:37 AM
Subject: CSR creation for AOS switches
We ran into this as well. You need to generate the CSR, then modify it, then you can request a cert from your CA.
Refer to:
https://learn.microsoft.com/en-us/troubleshoot/windows-server/windows-security/add-san-to-secure-ldap-certificate#use-certreqexe-to-create-and-submit-a-certificate-request-that-includes-a-san
Our INF file looks like this:
[Extensions]
2.5.29.17="{text}ipaddress=10.11.5.6&dns=SITE-2530P24G-1.internal.com&dns=SITE-2530P24G-1"
then we run the .CMD file to merge and create the certificate.
Original Message:
Sent: Jul 06, 2023 08:35 AM
I'm creating a CSR request for a 5412 switch to be submitted to internal CA ( Microsoft )
I'm in doubt about how to add, if possible, a SAN field in the request.
This is because I first generate the CSR as per the reference using only the common name like below
crypto pki identity-profile 5412vsf subject common-name 5412vsf.company.com country US org COMPANY org-unit IT State XX
crypto pki create-csr certificate-name 5412vsf ta-profile Company_CA key-type rsa key-size 2048 usage all valid-start 07/05/2023 valid-end 07/04/2033
However when I connect via browser I get the "usual" error about the untrusted connection and the problem is
NET::ERR_CERT_COMMON_NAME_INVALID
Subject: 5412vsf.company.com
This server couldn't prove that it's 5412vsf.company.com; its security certificate does not specify Subject Alternative Names. This may be caused by a misconfiguration or an attacker intercepting your connection.
