  • 1.  Customize Guest self registration
    Posted Mar 18, 2013 08:34 PM
    I have a customer with Amigopod 3.9 installed and working for guest self provisioning by sponsor email approval.
    When guest register and put sponsor email,  sponsor gets email request with link to activate.  It is working as it is.
    Default expire time set to 24hrs. Customer wants to have a option to change expiration time when approving request.
    Pages in question are
    guest_register.php - Guest self register page
    guest_register_confirm.php - Sponsor approval page opens by link in email
    guest_register_receipt.php -  Guest receipt page
    Issues I have are;
    1.  Page sponsor open with link on email is "guest_register_confirm" but this is not listed in "Customize Forms & Views"  section where we can edit forms.  When I add "expire_time"  field as Date/time picker on guest_register_receipt form it will display on both sponsor confirm page as well as guest receipt page.  We want expire time on date/time picker or drop down list (never  display) on sponsor page and static on guest receipt page.  Also even sponsor change expire time, it will not change actual field value and stay remain in default 24hr period.
    2. Changed default value of expire_time filed but it won't effect on guest.  All new guests having same 24hr default value.
    Only way to change expiration time is login to Amigopoad as admin or operator and change it manually.
    Thanks in advance
  • 2.  RE: Customize Guest self registration
    Posted Mar 20, 2013 06:51 PM
    Anyone have any thougts  ?
  • 3.  RE: Customize Guest self registration
    Posted Mar 20, 2013 08:17 PM
    You can extend the expiration time when the sponsor approves the account.  But this can only be a fixed value, you can't make it editable by the sponsor.
  • 4.  RE: Customize Guest self registration
    Posted Mar 20, 2013 08:22 PM
    Even that will be fine.  Can you please explain where to add this option.  Issue I am having is even I set expire_time as drop down list, it won't visible in sponsor page.
  • 5.  RE: Customize Guest self registration
    Posted Mar 21, 2013 01:51 AM
    Look under the "Actions" for the guest self-registration receipt page.
    In there you'll see an option called "Extend Expiration".  It's a fixed value, you can't have the operator change it when approving the account.
  • 6.  RE: Customize Guest self registration
    Posted Mar 22, 2013 12:10 AM
    Thanks,  Will try this
