Wired Intelligent Edge
CX 10000 and PSM
This thread has been viewed 137 times
  • 1.  CX 10000 and PSM
    Posted Sep 12, 2023 02:41 AM
    Hi brothers
         I have a cx10000 that needs to be tested and linked with PSM, but my psm does not seem to be completely associated with the CX10000.
    I don't have AFC, only PSM, I don't know how to proceed, AMD Pensando PSM for DSS Guide doesn't make me understand
    leo ma
  • 2.  RE: CX 10000 and PSM
    Posted Sep 12, 2023 08:43 AM
    Edited by Raghunandan Sep 12, 2023 08:51 AM
    Hi Leo,
    I assume you have already installed the PSM and its ready.  In this scenario we need to follow below to associate DSS (CX 10000) with PSM.
    Before proceeding further, make sure CX 10000 has L3 connectivity to PSM via mgmt/inband interface.
    The association of DSS with PSM can be done using CX 10000 CLI
    switch# conf t
    switch(config)# psm
    switch(config-psm)# host <ip address of the PSM cluster>
    Once this is done, your DSS should be associate with PSM.
    Verification can be done using System->DSS view, for a list of DSSes associated with this PSM.
    Alternatively, you can execute command in CX 10000 CLI which shows the admission status.
    switch# show􀁚 psm
    Policy and Services Manager Information
    Operational Status: admitted
    Host Addresses: <ip address of PSM host>
    VRF: default
    switch#
  • 3.  RE: CX 10000 and PSM
    Posted Sep 12, 2023 09:36 AM
    yes,my cx 10000
    10000# show psm
    Operational Status  : admitted
    Host Addresses      : 192.168.4.33
    VRF                 : default
    Source IP           : 192.168.4.33
    10000# show running-config psm
    psm
        host 192.168.4.33 vrf default
    The status is normal, but I don't know how to configure it on psm.
    For example, the following step in the guide:
    Where should I configure it, please ignore its status since I powered it off
    leo ma
  • 4.  RE: CX 10000 and PSM
    Posted Sep 12, 2023 11:00 AM
    Hi Leo,
    To configure the VRF, you need to navigate to Tenants-> VRF->Add VRF as below
    In the Tenants Tab, you can see most of the configuration option.
  • 5.  RE: CX 10000 and PSM
    Posted Sep 12, 2023 09:54 PM
    Hi Raghunandan
     My interface does not have Tenants
    leo ma
  • 6.  RE: CX 10000 and PSM
    Posted Sep 13, 2023 12:47 PM
    Hi Leo
    What is the version of PSM you are running? It's good to raise a TAC case to get it investigated.
  • 7.  RE: CX 10000 and PSM
    Posted Sep 14, 2023 11:09 AM
    Hello Leo,
    as I can see in the overview, there is an blue DSC card icon (instead of a Switch icon). It seems, that you did not use the "-distributed_services_switch" switch in the bootstrapping process.
    bootstrap_PSM.py -distributed_services_switch -clustername PSM01 -domain pensando.io -ntpservers X.X.X.X,X.X.X.X -autoadmit True -accepteula X.X.X.X
    Kind regards
  • 8.  RE: CX 10000 and PSM
    Posted Sep 14, 2023 11:24 PM
    Hi  MaxPower
    i am try run
    have error
    [root@PSM ~]# bootstrap_PSM.py -distributed_services_switch 192.168.4.33
    2023-09-15 03:22:40.184387: * all messages printed to the console will also be logged to the file: /var/log/pensando/pen-bootstrap-psm.log
    2023-09-15 03:22:40.184471: * start PSM bootstrapping process
    2023-09-15 03:22:40.184514: * - list of PSM ips: ['192.168.4.33']
    2023-09-15 03:22:40.184544: * - list of ntp servers: ['0.us.pool.ntp.org', '1.us.pool.ntp.org']
    2023-09-15 03:22:40.184622: * - cluster name: [cluster]
    2023-09-15 03:22:40.184653: * - using domain name: [pensando.io]
    2023-09-15 03:22:40.184677: * - auto-admit dse: [True]
    2023-09-15 03:22:40.184702: * - cluster-recovery-keys file path: [None]
    2023-09-15 03:22:40.184749: * - accept EULA: [False]
    2023-09-15 03:22:40.184815: * checking for reachability
    2023-09-15 03:22:44.195428: * connectivity check to 192.168.4.33 passed
    2023-09-15 03:22:44.548316: * PSM apigw is already running
    2023-09-15 03:22:44.548491: * enabling features
    2023-09-15 03:22:44.548592: * enabling smart services
    2023-09-15 03:22:44.755320: * error performing REST operation: POST https://localhost/configs/cluster/v1/licenses
    2023-09-15 03:22:44.755474: * server returned: 401 {"kind":"Status","result":{"Str":"Authentication failed"},"message":["updating feature flags allowed only during cluster bootstrapping"],"code":401,"object-ref":{}}
    2023-09-15 03:22:44.755994: * PSM bootstrap failed
    2023-09-15 03:22:44.756066: * please check connectivity, run /usr/pensando/bin/INSTALL.sh --clean on all cluster nodes and rerun /usr/local/bin/bootstrap_PSM.py (with switch -v for verbose logging)
    [root@PSM ~]# bootstrap_PSM.py -distributed_services_switch -clustername PSM01 -domain pensando.io -ntpservers 192.168.4.235 -autoadmit True -accepteula 192.168.4.33
    2023-09-15 03:16:23.409701: * all messages printed to the console will also be logged to the file: /var/log/pensando/pen-bootstrap-psm.log
    2023-09-15 03:16:23.409799: * start PSM bootstrapping process
    2023-09-15 03:16:23.409864: * - list of PSM ips: ['192.168.4.33']
    2023-09-15 03:16:23.409910: * - list of ntp servers: ['192.168.4.235']
    2023-09-15 03:16:23.409936: * - cluster name: [PSM01]
    2023-09-15 03:16:23.409961: * - using domain name: [pensando.io]
    2023-09-15 03:16:23.409985: * - auto-admit dse: [True]
    2023-09-15 03:16:23.410008: * - cluster-recovery-keys file path: [None]
    2023-09-15 03:16:23.410031: * - accept EULA: [True]
    2023-09-15 03:16:23.410059: * checking for reachability
    2023-09-15 03:16:27.420024: * connectivity check to 192.168.4.33 passed
    2023-09-15 03:16:27.681115: * PSM apigw is already running
    2023-09-15 03:16:27.681242: * enabling features
    2023-09-15 03:16:27.681287: * enabling smart services
    2023-09-15 03:16:27.867293: * error performing REST operation: POST https://localhost/configs/cluster/v1/licenses
    2023-09-15 03:16:27.867387: * server returned: 401 {"kind":"Status","result":{"Str":"Authentication failed"},"message":["updating feature flags allowed only during cluster bootstrapping"],"code":401,"object-ref":{}}
    2023-09-15 03:16:27.867730: * PSM bootstrap failed
    2023-09-15 03:16:27.867782: * please check connectivity, run /usr/pensando/bin/INSTALL.sh --clean on all cluster nodes and rerun /usr/local/bin/bootstrap_PSM.py (with switch -v for verbose logging)
    leo ma
  • 9.  RE: CX 10000 and PSM
    Posted Sep 15, 2023 01:21 AM
    Hi Leo,
    1. run: /usr/pensando/bin/INSTALL.sh --clean to cleanup all config on PSM and reset it
    2. run: bootstrap_PSM.py -distributed_services_switch -clustername PSM01 -domain pensando.io -ntpservers 192.168.4.235 -autoadmit True -accepteula 192.168.4.33
    Kind regards
  • 10.  RE: CX 10000 and PSM
    Posted Sep 15, 2023 02:54 AM
    Hi  brother
    i am change version to 1.54.3,
    I think the method you mentioned works fine. I'll try it with AFC.,thanks。
    leo ma
  • 11.  RE: CX 10000 and PSM
    Posted Sep 15, 2023 03:14 AM
    Hey Leo,
    you should better upgrade to 1.62.2-T-10. You´re using the CX10K with 10.12.1000, which requires an up to date PSM, otherwise you might run into issues.
    https://asp.arubanetworks.com/downloads/documents/RmlsZTo0YTQ1OGI0Mi0zYWI0LTExZWUtYTgzOC1kMzIzYmY3ODcwMjc%3D
    Kind regards
  • 12.  RE: CX 10000 and PSM
    Posted Sep 15, 2023 04:08 AM
    Hi brother
      yeap,There seems to be some problems when using 10.12. AFC cannot recognize the health status. I changed to 10.11.1041 and everything seems normal now.
    leo ma
  • 13.  RE: CX 10000 and PSM
    Posted Sep 15, 2023 04:25 AM
    Hi Leo,
    to run a successful PoC, I recommend to upgrade AFC / PSM and the switches so the latest versions.
    Keep in mind the upgrade path: AFC -> PSM -> Switches
    For further information, please take a look into the PSM User Guide:
    https://asp.arubanetworks.com/downloads/documents/RmlsZTo2NDU0NDM4NC0zYWI0LTExZWUtOTNhMC0wNzBkNzVhNjgxMTQ%3D
    Kind regards
  • 14.  RE: CX 10000 and PSM
    Posted Sep 17, 2023 11:08 PM
    Hi brother
      ok,  thanks
    leo ma
  • 15.  RE: CX 10000 and PSM
    Posted Mar 14, 2025 05:34 AM
    This PSM is new to me, and I have not received any support from SC or TAC. I am still facing challenges in implementing it
  • 16.  RE: CX 10000 and PSM
    Posted Mar 16, 2025 09:42 AM
    Please reach out to your Aruba SE to get the right support. They can help you to connect you with the right people
    Willem Bargeman
    Systems Engineer Aruba
    ACEX #125
  • 17.  RE: CX 10000 and PSM
    Posted Sep 14, 2023 11:12 PM
    Hi Raghunandan
    psm version 1.62.2-T-10,this is poc ,cant creat case
      thanks
    leo ma
  • 18.  RE: CX 10000 and PSM
    Posted Sep 15, 2023 09:36 PM
    then you need to get your local Aruba SE involved.
    I am surprised he/she is not involved.
